DRR Sim Update!
Discussion about the Disneyland Railroad
Post Reply
Steve DeGaetano
DRR Sim Update!
Post by Steve DeGaetano »
Just got an email from Preston:
The first update of the Santa Fe & Disneyland Railroad Steam Simulator is now available. Version 1.0.1 updates and changes include:
◾macOS version released
◾Added keyboard controls for throttle and Johnson bar
◾Added cab and headlight lamps response to generator charging
◾Added target FPS slider and lock
◾Speedometer now working when engine is moving backward
◾Added variable “auto” fireman control
◾Slightly tweaked the electrical system (now possible higher starting voltage value)
◾Changed/updated fire script to allow for auto firing and possible future feature expansion
◾Fixed crashing bug when auto firing is active
◾Updated the manual
Look for your original order email for the download link. Simply redownload the file and you will have the latest version, then install as usual.
A note about macOS: the Simulator is based on the OpenGL platform, and as far as I know, Mojave has completely left OpenGL for Metal, therefore Mojave is not officially supported at this time. The Simulator was built for and successfully tested on High Sierra (10.13.3 to be exact). (Which version do I have?)
Thanks for your support, and High Ball!
Jim Cook
Re: DRR Sim Update!
Post by Jim Cook »
Absolutely a GREAT sim!!! This exceeds the "Disney standards" that I've come to expect.
S. Towler
Re: DRR Sim Update!
Post by S. Towler »
Hooray! Just downloaded on my mac... but getting a non-responsive black screen after the "Made with Unity" startup screen. Animation fades in, then out, then nothing. Running 10.13.4
jbponzi
Re: DRR Sim Update!
Post by jbponzi »
I have the same issue running Mojave 10.13.4. From what I can see in the log may have to do with the version of Unity.
Justin
ktulu
Contact:
Re: DRR Sim Update!
Post by ktulu »
I just got a shiny new Mac mini with 64G/ram and two 32" 4K monitors (from work, home office), but running Mojave. Bummed about the lack of compatibilty right now :(
Post Reply
