We're still disassembling. When I was there last month, the steam pipes from the dry pipe to the steam chests were removed; we started removing the lagging and jacketing on the backhead; the injectors were removed; air tanks and cooling coils removed. Generator and bell taken off as well.tweetsie190 wrote: do you know the progress of #17's 5 year boiler inspection as required by the FRA?
The steam pipes, made of cast iron, had some broken flanges. These parts had been broken before in places, and showed signs of welding. They may need to be replaced with fabricated pieces.
I wasn't there yesterday, but the plan was to remove the smokebox door and the smokebox front. The plan is to get ready to lift the saddle tank off the boiler.
